Cant install the tune on a 2007 RAM 2500
Good Afternoon guys, I purchased a Predator U7131 for an 2007 RAM 2500 Cummins 5.9.
When I was trying to install the tune a message appeared : "Your vehicle is not in our database. Contact your dealer for a free update. Your CAL_ID is '50325053AB' "
(Which is actually the ECM Chrysler software pn which is up to date)
Tool is v.9r06 (I updated the tool with the serial cable, driver suggested and linking software given in the support tab).
Vehicle is a Dodge RAM 2500 Cummins 5.9 2007
VIN 3D7KS28C77G808483
Hope you can help me.
Thanks in advance,
Best regards.
Thanks in advance,
Best regards.
RE: Cant install the tune on a 2007 RAM 2500
This is a newer update than what we have added support for in the tool.
We are working on a new update (9r07) that will add support for this cal.
Ups. Doesn't sound good. And when could that release could be available? Now puting it in another scenario, What 2007 Dodge Cummins Cal id does this support?
Thanks for your response.
Best regards,
Best regards,
It supports everything up to cals that were released since we made 9r06, a few months ago.
I get your point. I´m going to put it this way, I'm able to re flash the Cummins ECM with Dodge Cal id . For MY 2007 with 48RE tranny , original flashes are:
50325053AB Ref N°68029123AA Auto federal late build. (this is the one the truck has)
45325753AG Ref N°53040529AF Auto federal
45325733AG Ref N°53040530AF Auto California
This pn supersedes previous pn obviously but are the latest that are available for ECM flashing by Chrysler. If I reflash the ECM with 45325753AG Auto federal , predator v.9r06 could support it?
Thanks in advance,
Best regards.
Thanks in advance,
Best regards.
You're saying you can go backwards?
If so, I'll have to do some digging, but the starscan does not generally support going backward without some inside knowledge....
OK, read my PM.
Still does not answer my questions at all...?
Try again, I was writing what you was asking.
Now its in your PM.
Now its in your PM.
OK, gotchya.
Lemme look it up.
Lemme look it up.
Great. Thanks in advance. I'm going next week to Atacamas Raid and hopefully with the predator loaded in order to fly in the sand dunes
http://www.raid-atacama.cl/
Hoping to hear soon from you.
Best regards.
Best regards.
Tune installed and running
Cal id 45325753AG is supported by U7131. This cal id is Early Federal + Auto Emissions.
50325053AB corresponds to Federal + Auto Emissions Late Build and its not supported by v.9r06 .
Thanks anyway.
Best regards.
Thanks anyway.
Best regards.
HI THERE. I HAVE THIS CALID PROBLEM YOU WERE HAVING SEE MY POSTS FOR DETAILS BUT I AM INTERESTED IN HOW YOU GOT THE DEALER OR WHOMEVER TO REFLASH YOUR VEHICLE TO AN OLD CALID???? I HAD A ECM FAILURE ON MY 06 CUMMINS AND THIS CAL ID IS WHAT I WAS LEFT WITH AND I HAVENT USED MY PREDATOR IN OVER A YEAR BECAUSE OF IT. DIABLO HAS NOT HELPED ME YET AND GETTING A LITTLE FRUSTRATED. MY TRUCK RAN WAY BETTER WITH THE STOCK PROGRAM WHICH THE DEALER SAYS THEY CANNOT GO BACK TO NOW IN THERE SYSTEM BUT I WOULD SURE LIKE TO GET THAT OLD FLASH BACK WHICH SOUNDS LIKE WHAT YOU DID OR FOUND TO DO. CAN YOU HELP??
