How to return to stock tune
Posted: Sun Jan 23, 2011 2:31 pm
by cobra0478
I have an 07 GT500
I am using the predator U7145
I need to return to stock for dealer visit.
instructions are not clear.
options are
import custom tune
export original backup
export last written
erase custom tune
What do I do??
Thanks Don
RE: How to return to stock tune
Posted: Sun Jan 23, 2011 2:36 pm
don't go into the options...
from the main menu, select Performance Tune...
then one of the choices in there should be "Original Backup"... select that, and it will restore your original backup...
Posted: Sun Jan 23, 2011 2:40 pm
by cobra0478
I will try that now.
Don
Posted: Sun Jan 23, 2011 2:55 pm
by cobra0478
I did as you said,options were.
diablo tunes
custom tunes
chose custom tunes,reinstalled tune set for myself.
Rebuted and same options came up.
Checked diablo tunes,there is an option at the end for
original backup.
Is this the factory tune??
Don
Posted: Sun Jan 23, 2011 3:02 pm
yes
Posted: Sun Jan 23, 2011 3:09 pm
by cobra0478
I will do that now.
Don
Posted: Sun Jan 23, 2011 4:49 pm
by cobra0478
Problem solved.
Thanks.
Don
Posted: Sun Jan 23, 2011 5:09 pm
cool...
np man, you're welcome!
Posted: Wed Mar 16, 2011 4:39 pm
by director1203
after restoring the original tune i can then change ECUs and use the Predator on my new ECU correct?
Posted: Wed Mar 16, 2011 4:51 pm
as long as it's a supported pcm for that model predator...
Posted: Wed Mar 16, 2011 5:12 pm
by director1203
yes same vehicle. just changing the ECU back to a stage 1 from a stage 2 ECU in my SRT4
Posted: Wed Mar 30, 2011 4:42 pm
by Chadclark
How Do I clear out a previous cars Vin number from my Diablosport predator tunner? I put a chip into my mass flow system and made my RPMs go way up to where it should not be will i recalibrate the RPMs?
Posted: Wed Mar 30, 2011 4:54 pm
you can't unlock it... you need to call tech support...
Posted: Wed Mar 30, 2011 4:58 pm
id start by getting rid of whatever chip you put in your MAf...sounds like a recipe for disaster.
