shift point questions
Posted: Tue Jan 25, 2011 5:20 pm
by muddyXLT
I'm new at the tuning thing and have a question. I have an 04 f150 and im not sure how to adjust the shift points. I put 35's on it and got the speedometer right but im in 3rd gear too long. when it shifts into 4th its really high on the rpm's and then i have to let off the thottle some to shift into overdrive. any suggestions on how much to tune up or down? Thanks
RE: shift point questions
Posted: Tue Jan 25, 2011 5:43 pm
First thing Id wonder is if the speedo is actually correct.
If so, adjust the WOT shift point down a few hundred RPM and try that.
Posted: Tue Jan 25, 2011 11:01 pm
by muddyXLT
Ok thanks i will try tomorrow after work but what does WOT mean
Posted: Tue Jan 25, 2011 11:52 pm
by muddyXLT
another thing i should add is its a daily city driver and i dont get on the throttle much. I just dont see why Im in 3rd for so long. thanks again
Posted: Wed Jan 26, 2011 9:49 am
by diablojesse
WOT = Wide Open Throttle
Posted: Sun Jan 30, 2011 12:30 pm
by ESM
What's the difference between changing shift points using RPM versus MPH? I'm also new at modding just trying to figure out what some of these parameters do. Thanks!
Posted: Mon Jan 31, 2011 12:07 pm
You have to hit the commanded MPH before it will allow the RPM shift to happen.
Posted: Wed Feb 02, 2011 4:25 pm
by ESM
so right now even with rev. limit off and shift point (RPM) set at 6000, car shifts around 5600 almost every gear going WOT from a dead or rolling stop. However, if i'm already driving (let's say highway) and go WOT shifts are even lower at about 4k...do I need to change the RPM shift points or the MPH points to fix this?
Really I'm just trying to improve "pass-ability" so reduce that lag from gas --> down shift --> go!
