05 mustang gt airaid 91 oct problems
davefriedrich
Post by davefriedrich »
preditor u7140 updated to latest
05 ford mustang gt i filled the gas tank with 93oct took out insert and tuned it first to airiad 93oct firm shifts and right away got errors and check traction control so i retuned it to airaid 91oct and got 4 error codes anyone have same problem should i just use 93oct with insert in or do i need a custom tune
tuningss
RE: 05 mustang gt airaid 91 oct problems
Post by tuningss »
The firm shift tune disables traction control, so that is normal, but what were the other codes? Read the codes and post them up, but if you decide you want a custom tune, we can help there as well.
http://www.tpctuning.com
davefriedrich
The codes im getting are(mass air sensor is in proper direction and used 93 oct)
P0104
P0171
P0174
P1000
Check for leaks ;)
ESM
Post by ESM »
P1000 will reset after some driving (there is a specific set of driving instructions from Ford, but if you just do some combined city + highway it should clear itself after 50-100 miles)...the other P codes...good luck!
Return to “Predator Ford Gas”
