WOW still no solution
Posted: Mon Feb 21, 2011 2:05 pm
by maddad
still cant use the diablo,, Ive posted before about this problem (300 bux wasted) when i try to install the tune from my 2nd diablo because Ive returned the first one thinking it was bad it does the same shit (doesn't see my ignition on) WTF.
DOES ANY ONE FROM TECK SUPPORT now the fix of this problem WOW ive waited a few months to see if they could figure this out, Ive seen many more diablo buyers had the same problems.If any other owner fixed this problem please PM me or post so others can enjoy what they buy from this so called Tuner.
RE: WOW still no solution
Posted: Mon Feb 21, 2011 2:14 pm
since you've had the problem with two different units, obviously it's an issue with your vehicle, not the tool...
have anything aftermarket installed in the vehicle?? it's probably something connected into the ignition wire for power, so it's disrupting it...
if you have anything aftermarket installed in the vehicle, it needs to be disabled/disconnected/fuse pulled for it so that it doesn't interfere with the tools communications...
Posted: Mon Feb 21, 2011 3:05 pm
what vehicle is this?
if pre-04 stang, any chance there is a chip installed?
Re: RE: WOW still no solution
Posted: Mon Feb 21, 2011 3:12 pm
by maddad
06MonteSS wrote:since you've had the problem with two different units, obviously it's an issue with your vehicle, not the tool...
ITS AN 07 NO CHIP
RE: Re: RE: WOW still no solution
Posted: Mon Feb 21, 2011 3:16 pm
any chance you can try it in a different vehicle?
Re: WOW still no solution
Posted: Mon Feb 21, 2011 3:18 pm
by maddad
maddad wrote:still cant use the diablo,, Ive posted before about this problem (300 bux wasted) when i try to install the tune from my 2nd diablo because Ive returned the first one thinking it was bad it does the same shit (doesn't see my ignition on) WTF.
WELL I GUESS EVERY ONE THAT HAS THIS PROB HAS AN AFTER MARKET OR SOMETHING AND THAT WHY IT WONT WORK.I HAVE EVERY THING STOCK.BESIDES HID HEADLIGHTS.I HAVE UNPLUGGED THEM ALSO,STILL NOTHING.AND IM SURE EVERY ONE ELSE HAS PULLED,UNPLUGGED,REMOVED,THERE AFTER MARKET SHIT ALSO.SO NO ITS NOT MY CAR
Posted: Mon Feb 21, 2011 3:19 pm
by maddad
ITS A 07 GT ROUSH
Posted: Mon Feb 21, 2011 3:42 pm
by maddad
ITS AN 07 NO CHIP
NO THERS NO ONE THAT I KNOW THATS TRUST DIABLO AND DONT WANT TO CHANCE THE PROBLEM DIABLO GIVES.
Posted: Tue Mar 01, 2011 2:00 am
by speedshop
What is the problem? What is the car doing? There are a lot of issues with the 2 piece spark plugs in those cars if you have a misfire that may be it. The programmer is not going to cause ignition problems.
