BLANK SCREEN AFTER REVISION U7158
jnazario
Post by jnazario »
IT STARTED RIGHT AFTER I FINISHED UPLOADING IT TO THE PREDATOR.
I DID EVERYTHING THE INSTRUCTION SAID, EVERYTHING WAS GOING FINE.
NEED HELP PREDATOR ISN'T DOING ANYTHING :(
RE: BLANK SCREEN AFTER REVISION U7158
Sounds like you tried to update an older tool to the latest revision.
Try reloading the 8r10 crom from that page.
jnazario
Post by jnazario »
even if the predator cannot be recognized by the DsDownloader?
jnazario
Post by jnazario »
i tried what was suggested but when the DsDownloader asks to cycle
predator it just doesn't recognize the predator so it wont upload old revision
sounds like wrong com port is selected.
jnazario
Post by jnazario »
its on auto detect
jnazario
Post by jnazario »
ive also tried manually doing it.
use legacy connect, and select the correct com port.
jnazario
Post by jnazario »
is the reason that this happened because i tried to load a revision that is to
new? is there a revision for my older predator?
yes, as mentioned in my first post, you need to load 8r10.
jnazario
Post by jnazario »
yeah i got that thanks.
its working again thanks for the help.
Return to “General Support”
