Predator part number---- u7186
Truck------ 2010 dually, chevy, 3500
Im receiving a "writesafe" failure message when trying to install a performance tune..... I have park brake on, key turned to the on position(truck is not running), radio off, air off, lights off...... I choose 60hp then it runs its course then when its just about to be finished it throws that "writesafe failure" message and tells me to unplug tuner.
Any help or suggestions?
Im receiving a "writesafe" error message
RE: Im receiving a "writesafe" error message
is it failsafe?
does the truck run when it is done?
Does it go into recovery mode and prompt you to restore the stock tune?
Bryan10dmax
It's says Write failed (failsafe) when I press more info it says ECM: error unlock for reflect(-1) my only option after that is continue and it tells me to unplug tuner.
Yes the truck runs.
Yes the truck runs.
OK, does this happen when trying to save the backup?
Bryan10dmax
No it does not..... I can return my truck to original backup that works just fine.... It only gives me that message when I try to install a tune ( towing, 60hp, 80hp etc)
can you post your VIN number?
