Trinity stopped working?
metalsystem761
Post by metalsystem761 »
The trinity doesn't work when I plug it into my truck it will only turn on when it is plugged into a computer?? Has been for 2 weeks now..
leadfart
RE: Trinity stopped working?
Post by leadfart »
Did you check your fuse box? Fuse has been known to pop.
yeah.. check all your fuses in the truck, especially a cig lighter and aux. power fuses... the obd port gets its power from those...
you can also plug it in to ANY other 2000 or newer vehicle's obd port to check it - does it power up??
OnkelMatze
Post by OnkelMatze »
probably Trinity docking pins damaged;
I´ve had the same issues; sent it as RMA to DiabloSport,
now it´s working properly
Return to “Trinity GM Gas”
