9r20 upgrade problem with 7194
jozek
Post by jozek »
on device installed 9r19, when try to update firmware to 9r20 there is no succes.. on LCD of predator message appears "Can't downgrade u7194 from 9r16 to 9r20".
What I should do to upgrade with newest revision?
jrodela06
RE: 9r20 upgrade problem with 7194
Post by jrodela06 »
how old is your u7194? im not sure but i was able to upgrade from 9r05 to 9r20 and now i cant upload tune to truck.
jozek
Post by jozek »
not that old, I think.. I bough it at the end of 2009. Every older upgrade went OK, but strange, the newest one had problem.
Oldviolin
Post by Oldviolin »
My u7194 is a 2009. Will I beable to upgrade to r20?
You should be OK.
Oldviolin
Post by Oldviolin »
Will updating help with shift firmness? I'm at v.9r08 now
if you have a 6 speed trans, yes.
Oldviolin
Post by Oldviolin »
I have the 4 speed. My shifting is nice at normal to moderate acceleration. At WOT I feel nothing
rjaro7
Post by rjaro7 »
same problem here..i have 9r18 now and tried 9r20..tuner says cant downgrade 9r16 to 9r20..
2010 GMC Sierra 5.3 Flex
sonic13
Re: RE: 9r20 upgrade problem with 7194
Post by sonic13 »
rjaro7 wrote:same problem here..i have 9r18 now and tried 9r20..tuner says cant downgrade 9r16 to 9r20..
all the same probs here when i try to go from 9r18 to 9r20 -> cant downgrade 9r16 to 9r20 (it's a 2010 predator 7194)
load this then 9r20
u7194-9r19.crom
(1.24 MiB) Downloaded 161 times
