Page 1 of 2
Smooth MDS and Increase Throttle Response
Posted: Sun Mar 06, 2011 2:41 pm
by adbutz
Hey Mikel can you Smooth the MDS surge and Increase throttle response for the 91 octane cai tune. Its my last written and I attached it.
If possible could you do the same for my original back up
I have U7135 with the last crom update(9r28)
My car is a 2009 Dodge Charger with the 5.7L engine
Aaron
RE: Smooth MDS and Increase Throttle Response
Posted: Sun Mar 13, 2011 3:30 pm
by adbutz
Hello
I'm just wondering if I could get that MDS smoothing tune for the above files.
Aaron
Posted: Mon Mar 14, 2011 11:37 am
here you go
Posted: Mon Mar 14, 2011 12:17 pm
by adbutz
Thanks. Do I have to re-install the original back-up before I download and install this tune
Posted: Mon Mar 14, 2011 12:27 pm
No...
Posted: Mon Mar 14, 2011 12:41 pm
by adbutz
perfect, thanks again
Posted: Mon Mar 14, 2011 2:48 pm
If you update to the latest revision, you can adjust the throttle sensitivity yourself.
Posted: Wed Apr 13, 2011 11:49 am
by adbutz
Hey Mikel, just a quick question on this tune. When you send the tune back with the smooth, is it still a 91 cai tune or should it be considered a whole new tune in itself. The only reason I ask is because finally the roads were dry and ready for some 0-60 times. When I attempted them, I was actually getting worse times than without the predator. Before the predator(stock), I was getting 0-60 times of around 5.5 seconds but with this tune I have yet to get under 6 seconds. Would running the 91 cai tune without the smooth be any better. I purchased this unit to get better times not worse. On a brighter note, the everyday driving with the smooth is much better, ie less drone/stutter when mds kicks in and for this I am grateful. But I would like to push this car to the low 5 second mark if possible. Thanks Aaron
Posted: Wed Apr 13, 2011 12:28 pm
yes, same tune you posted just with the smoothing applied.
Posted: Thu Apr 21, 2011 10:07 pm
by worlthompson
Mike What did you adjust on the tune to smooth out the MDS???
Posted: Thu Apr 21, 2011 11:12 pm
by WKgrand08
I am curious as well since I am experiencing the same on my end.
Posted: Fri Apr 22, 2011 8:53 am
worlthompson wrote:Mike What did you adjust on the tune to smooth out the MDS???
you can compare the files and see
simple timing change...
Posted: Fri Apr 22, 2011 9:08 am
by frankiek
I would pull the F2 fuse for a couple of minutes, the adaptives may be hindering you. My 09 Rt runs consistently in the 5.1 range with the 91cai tune. Fastest has been 5.0, I dont think its the tune.
Posted: Fri Apr 22, 2011 9:26 pm
by dnar
mikel wrote:worlthompson wrote:Mike What did you adjust on the tune to smooth out the MDS???
Hi Mike,
How about sharing the details with us please?
Posted: Sat Apr 23, 2011 11:33 pm
by adbutz
Hey mikel, I was on hypertechs web page and they had an interesting way of controlling the mds. Their tuner could be programed to deactivate mds below a certain speed which the owner could choose. I was curious if diablo's working on something similar, or if something like that is being discussed, as this would be one way of getting good mileage on the highway, while not having that pesky drone while in town. Aaron
