boost gauge does not work after updating to the 1r08 crom.
General Trinity Support
danno530
Post by danno530 »
I have a 2003 Pt Cruiser Gt. boost gauge worked fine on the trinity before i updated to the 1r08 crom now it stays at 0 boost so i updated it agiin and it still not working. anyone have any ideas? please help.
jimb
RE: boost gauge does not work after updating to the 1r08 cro
Post by jimb »
Can you try monitoring MAP and BARO. What do they show?
danno530
Post by danno530 »
Yes they work. baro 96.60 map reads around 32.80 .
jimb
Post by jimb »
With BARO=96.6 kPa and MAP=32.8 kPa; The Boost Synth PID will be 0.
Boost only shows > 0 when MAP > BARO.
danno530
Post by danno530 »
yes that was at idle map changes a lot when driving. just don not understand why boost synth worked fine before and when i updated it quit. i also tried making a new gauge layout with a synth boost gauge and still not working all the other gauges seen to work fine.
danno530
Post by danno530 »
map goes >baro just went and checked
can you log that and post it?
danno530
Post by danno530 »
hope i did this right
jimb
Post by jimb »
You did it right. Your log is showing BARO and "READ MAP kpa" non-standard PIDs which were used to calculate Boost for early SRT4 ECUs. In the more recent DCX Gas 1R08, we switched to using standard PID's which don't work on early CalIDs. It's something that needs to get fixed in next DCX GAS release.
danno530
Post by danno530 »
so i need to wait for a update to get my boost gauge working?
BoostedSRT4
Post by BoostedSRT4 »
Mine isn't showing up at all and I tried looking in every PID for it and still no luck.
2005 Dodge ACR SRT4
Flakdodger
Post by Flakdodger »
Can I go back to old rom until boost monitor issue is resolved for the PT GT's?
2004 SRT-4, Stage 2 w/o toy, 55mm TB, 3" exhaust w/dump, Hurst Shifter, Mopar Intake, N2MB WOT/2 step, Poly mounts, Diablo Trinity 93 tune
fix is here:
trinity_dcx_gas-1t08aa_update.crom
(2.4 MiB) Downloaded 513 times
danno530
Post by danno530 »
Thank you Mikel boost gauge is working now !!!!!
Thanks for the feedback.
Return to “General Trinity”
