Is there a 9r28l?
Is there a 9r28l?
Mike? I wanna play with the throttle booster. Is there an "l" version of 9r28 yet? Stuck with 9r12 for now because of the stupid memory issue (can't it be repartitioned to allow more CROM space and less logging space?).
I'm gonna blow this transmission sky high before I replace it. :twisted:
RE: Is there a 9r28l?
already sent it....
mjf6866
Post by mjf6866 »
mikel, can you please clarify if the booster is available in the one on the download page?
and why isnt the "l" version found on the download page?
throttle booster is in 9r28, yes.
mjf6866
Post by mjf6866 »
thanks for the response Mike...can you confirm if it will work in my 6-speed?
also, what is the difference between the "l" version and the regular 9r28?
thanks again
No, throttle booster is an auto only thing, sorry.
bigsnake
Re: RE: Is there a 9r28l?
Post by bigsnake »
mjf6866 wrote:thanks for the response Mike..
thanks again
l version is a shorter version that goes with the older predators because they have less memory space.
Bigsnake
10 Charger SRT8
11 Mustang Shelby GT500
muskegoil
RE: Re: RE: Is there a 9r28l?
Post by muskegoil »
can i get a 28l too,older predator 2007 for 2009 charger srt thanks,,,,
2009 Charger SRT,91 tune 180 thermo
Let s see if I can post it...
u7135-9r28l.crom
(956.98 KiB) Downloaded 254 times
brandy16
Post by brandy16 »
Mike_Levy wrote:Let s see if I can post it...
Hi Mike where did you get it from. I have a new computer with windows 7. I tried to save it to my desk top but it would not do it. Must be doing some thing wrong.
I got it from Mike Licht. I have Win7 too and it saved fine. When you click Download, you should get a window with choices of Find, Save or Cancel. Hit Save. You'll get a prompt for what to save it under and where. Pick the place you want it, leave the filename as is. Save As type should be CROM file. Hit Save and it should download to where you just put it.
brandy16
Post by brandy16 »
Thanks I finally got it to work don't know what I did wrong the first time.
geoflee
Post by geoflee »
Thanks Mike. I also had problem with "missing serial flash" message on predator. Will try this 9r28 lite version
cheers
geoflee
Post by geoflee »
The crom v9r28l updates my predator fine-ok.
Connect predator to 2006 300C 5.7l export model and message displayed
"v9r28l does not support this vehicle CAL ID"
Guess I'll have to revert to v9r12 unless someone can offer work around for me.
cheers
I'm thinking they probably remove the early CalIDs to make the files smaller. They need to remove something, so thats what I'd expect.
