NEW TO THE DEISEL WORLD...HELP ME PLEASE.
I JUST GOT A U7131 PROGRAMMER FOR MY 06' DODGE MEGACAB 3500 SINGLE AXLE...Ii TRIED THE TOW MODE THIS PAST WEEK-END AND WOW...IT WORKED GREAT.
WHAT IS THE BEST SETTING FOR DAY TO DAY RUNNING WITHOUT THE TRAILER...THE TRUCK IS STOCK EXCEPT FOR AN K&N INTAKE KIT.
MY REAL QUESTION IS IN REGARDS TO THE EXTREME RXL TUNE...IT SAYS TRANSMISSION MODS ARE REQUIRED...WHAT MODS ARE REQUIRED...AS I DONT WANT TO BLOW UP MY NEW TRUCK....
IS THE STACKER WORTH THE MONEY...AS I OPTED OUT AND JUST GOT THE PROGRAMMER. BECAUSE I WAS NOT SURE WHAT IT REALLY DID.
WHAT ELSE WOULD BE GOOD TO GET TO MAXIMISE THE PERFORMANCE OF MY PROGRAMMER..OR WHAT ELSE SHOULD I RUN TO BE ON THE SAFE SIDE.
THANKS IN ADVANCE,
MR. NEW GUY
THANKS IN ADVANCE,
MR. NEW GUY
RE: NEW TO THE DEISEL WORLD...HELP ME PLEASE.
on the safe side use a exaust guage....remove the resonator or "cat" if its to hot! or go with a mandrell bent full exaust.
the perf. tune was my best fuel milage but that is diff. for some.
Nick,
Smart Line products
06 Dodge 6 speed,4x4 dually on 265/70/19.5's
predator POWER!!!
95' dodge diesel with 165k that sounds better than my 06?
Smart Line products
predator POWER!!!
Dodgezilla
You will need a minimum of a better converter and valve body. That's for starters. You really need a fully built trans to run that all the time. Your truck is probably making around 425-430rwhp on the Extreme RKL tune. That's a lot for the stock trans to handle...
As for the Puck, just keep what you have! It runs better and rail pressure is much lower w/ just the Predator...
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
- duallydave
cameroneod
THANKS FOR ALL THE HELP GUYS,,,REALLY. I NOW HAVE ANOTHER QUESTION CAN I SAFELY RUN THE EXTREME SETTING WITHOUT DOING ANY MODS TO MY TRANS ORTRUCK,. OR DO I NEEAD A GUAGE OF SOME SORT OR JUST LEAVE IT ON THE PERFORMANCE SETTING...I KNOW THE EXTREME RXL SETTING IS OUT UNLESS I DO SOME TRANS MODS.
LET ME KNOW....THANK
P.S. ANY OTHER QUICK AND DIRTY TIPS FOR MORE POWER !!!
Dodgezilla
If you want to be safe then stick to the tow tunes. Anything higher will deteriorate your trans eventually...
Go to www.dieseltruckresource.com to answer all your questions about other mods for your truck. BEWARE though!!!! Once you start you can't stop!!!!
- duallydave
- duallydave
Dodgezilla
- madmanwithmouse
Also, if I run my puck alone and stay in it, it will climb to 1300 at 70ish and keep going higher if I didnt let up. The tow tune is my favrite for generl driving and trailer pulling, good throttle responce but it is also smooth. Not to mention the egts won't go much above 1000(preturbo). I get 17ish mpg but could do better if my foot would just listen to meAs for the Puck, just keep what you have! It runs better and rail pressure is much lower w/ just the Predator...
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
- madmanwithmouse
Id say so long as you are not in it very hard you should be fine tranny and egt wise, but if you get in it relly hard you are most likley gonna have a toasty engine.I ASKED THE GUY AT THE STORE WHERE I BOUGHT MY PRED ABOUT RUNNING ON EXTREME MODE AROUND TOWN...AND HE TOLD ME NO PROBLEM...WHAT DO U GUYS THINK....I DONT HAVE AN EGT TEMP GUAGE OR ANYTHING LIKE THAT.
