Throttle boost or sensitivity? 07 ram
Josh07hem
Post by Josh07hem »
Hey fellas i just got the newest crom in. u7137-r911. In the parameters throttle sensitivity was replaced with 'throttle boost' is there a difference? or is it just the word?
Thanks for your help
RE: Throttle boost or sensitivity? 07 ram
same param, new name :)
Josh07hem
Post by Josh07hem »
thanks
69rrbruce
Post by 69rrbruce »
Why would you change to the term "throttle boost"?????? Doesn't make any sense!
it boosts the throttle....
silverdaytona
Post by silverdaytona »
So what is added or improved on 9 revision 11 that was not on 9 revision 10?
69rrbruce
Re: RE: Throttle boost or sensitivity? 07 ram
Post by 69rrbruce »
mikel wrote:it boosts the throttle....
Sounds like an uninformed computer geek vs. a gear heads description to me. :wink: Sorry, throttle sensitivity was more accurate.
RE: Re: RE: Throttle boost or sensitivity? 07 ram
If you look, there is a good reason for the use of the term 'booster', as there is another company making a killing on a device by that name ;)
Also, you and I may be gearheads, but the reality is, 75%= of our customers are not :)
