02 mustang gt w/procharger & mafia
Should maf reading on scanner with koeo be same as stock parameter .6-1 volt ? Mine's reading 5.12 and running poorly. Need info asap . Thanks
RE: 02 mustang gt w/procharger & mafia
its a 0-5 V sensor, you should not be seeing that much voltage.
What does it look like at idle?
Do you have a MAFia installed?
Yes, MAFia is installed. If I take out of system car will idle normally
no, that wont help, you need it there if the tune is set up for it.
Id rma the mafia if voltage is not right at idle.
what's your procedure,
bought car with unit installed
