#s to enter in Trinity to log AFR w/ Autometer wideband ???
Posted: Sat Apr 09, 2011 5:38 pm
by SRT8_in_CT
Can anyone tell me the exact high and low values to enter into the Trinity for an Autometer wideband? It's been trial and error so far, and I got it close, but would like it perfect if possible..I don't know where to find the #'s .. Anybody logging AFR w/ an Autometer??
Thanks in advance..
Ken
RE: #s to enter in Trinity to log AFR w/ Autometer wideband
Posted: Sat Apr 09, 2011 5:39 pm
by SRT8_in_CT
BTW.. It's in a 2006 Charger SRT8 with a 6.1 ... brand new Trinity w/ latest software
Posted: Sat Apr 09, 2011 6:48 pm
by SRT8_in_CT
Well, I went from bad to worse.. In searching I came across a "good" thread, so I reset to default and entered new parameters.. Now all I have is volts where before I had AFR readings... Arghhh
Posted: Sat Apr 09, 2011 7:06 pm
by jimb
The default analog input is in Volts. In the same analog configuration, You can "Add" a new input specifying your upper and lower values. The label and units can be whatever you want.
Re: RE: #s to enter in Trinity to log AFR w/ Autometer wideb
Posted: Sat Apr 09, 2011 8:15 pm
by SRT8_in_CT
jimb wrote:The default analog input is in Volts. In the same analog configuration, You can "Add" a new input specifying your upper and lower values. The label and units can be whatever you want.
Thanks ... I can't seem to get to that add new input part.. This is what I did...
Trinity input range is 0-5v. Your autometer is 0v == 15.1 AFR, 4v == 10.1 AFR (Please check it's not 0 == 10.1 and 4v == 15.1).
Do the following:
- Options -> Analog Input Config -> Reset All defaults. (Start fresh)
- Options -> Analog Input Config -> Add a New Parameter.
- Enter a Name (e.g. "My AFR")
- Select the analog input chanel. (1 or 2 depending which wires you used. see: http://www.diablosport.com/index.php?na ... 14&start=0)
- Change Units. (It defaults to "Volts". Change it to "AFR" or anything you want using the '<' button)
- Enter Lower Bound: 15.1 ( maps to 0v)
- Enter Upper Bound: 8.75 ( maps to 5v)
I can't figure out how the '<' button works? It just erases volts on the screen.
Posted: Sun Apr 10, 2011 11:48 am
by SRT8_in_CT
Do the following:
So is there a drop down menu somewhere to select AFR instead of the default Volts? If I use the '<' button I can erase volts and type in AFR, but it still displays in volts ..
What am I missing, gotta be something stupid?
Thanks in advance
RE: Re: RE: #s to enter in Trinity to log AFR w/ Autometer w
Posted: Mon Apr 11, 2011 8:17 am
by gizmodo
That's the backspace button. Delete the word volts and type AFR.
Re: RE: Re: RE: #s to enter in Trinity to log AFR w/ Automet
Posted: Mon Apr 11, 2011 8:28 am
by SRT8_in_CT
gizmodo wrote:That's the backspace button. Delete the word volts and type AFR.
Exactly what I did, but still displayed in Volts .. I will try again from scratch today.. Thank you
RE: Re: RE: Re: RE: #s to enter in Trinity to log AFR w/ Aut
Posted: Mon Apr 11, 2011 11:01 am
by gizmodo
Did you select your new analog pid when creating the dashboard?
Re: RE: Re: RE: Re: RE: #s to enter in Trinity to log AFR w/
Posted: Mon Apr 11, 2011 4:10 pm
by SRT8_in_CT
gizmodo wrote:Did you select your new analog pid when creating the dashboard?
I think that's where I went wrong.. Started again from scratch and finally got the AFR on the autometer gauge super close on the Trinity ..
However, when I entered the following #'s from a post above it was nowhere close...
I wound up experimenting and settled with 10.0 as the lower bound, and 17.5 as the upper.. I'm now within .05 to .1 difference between the Autometer AFR gauge and what's showing on the Trinity.. Pretty close ..
Thanks for the help
RE: Re: RE: Re: RE: Re: RE: #s to enter in Trinity to log AF
Posted: Mon Apr 11, 2011 5:00 pm
by alittletippy
srt8 you had it backward with the previous settings. you are right with what you did at the end of your last post. Lower boundry is just that, the lower limit of your reading and upper boundry is upper limit. I use a autometer wideband in my srt4, but i cant remember my settings. your settings look close.
Re: RE: Re: RE: Re: RE: Re: RE: #s to enter in Trinity to lo
Posted: Mon Apr 11, 2011 8:11 pm
by SRT8_in_CT
alittletippy wrote:srt8 you had it backward with the previous settings. you are right with what you did at the end of your last post. Lower boundry is just that, the lower limit of your reading and upper boundry is upper limit. I use a autometer wideband in my srt4, but i cant remember my settings. your settings look close.
Agreed .. I was going on the post by jimb ..
Do the following:
I wound up with 10.0 low and 17.5 high and shot a video and when I stop it, it's real close ...
Posted: Mon Apr 11, 2011 11:41 pm
by mckwre
SRT8_in_CT wrote:BTW.. It's in a 2006 Charger SRT8 with a 6.1 ... brand new Trinity w/ latest software
yes,you can find it.
Posted: Tue Apr 12, 2011 9:31 am
by SRT8_in_CT
Find what? Would you care to elaborate? Thanks
