Predator U7158
v.9r03
2001 Ford Lightning with stock MAF and 6lb lower pulley.
My question is how do I tune the truck once I plug in the MAFIA?
I have access to a dyno for as long as I need it.
I also have an Innovate MXL Wideband already installed.
Without the MAFIA:
My truck is at 11.2 A/F WOT @ 5200 RPM's, my MAF Volts are 4.71, 18 degrees of timing.
Thanks in advance!
How do I tune for MAFIA with Predator?
2001LightningSVT
RE: How do I tune for MAFIA with Predator?
You need a custom tune from a CMR dealer for using a Mafia, there is no other option.
2001LightningSVT
Why? I have a Predator and a Mafia, why would I need to get a custom tune from a dealer? I was told to simply buy the Mafia when I bought my Predator and they would do what I need to do.
Sorry, no, that is not the case.
Adding a Mafia requires custom tuning.
2001LightningSVT
Can you be more specific? Does my Predator not have the ability to tune my truck with the Mafia?
tuning for the Mafia requires changes to things that can only be altered in custom tuning software like airmass displacement of 1 cylinder, and the high and low injector slopes. Again, as we list in the provided info for the Mafia, there is no way to plug it into a vehicle without having a custom tune created for it to work properly.
