2009 sierra 5.3l any recommendations for tune with predator?
Posted: Sun Apr 17, 2011 7:09 pm
by thunderwolfx
i have a predator u7194 not sure which revision i'll have to check, I know that I have to update to the 09 update yet. i have a 09 gmc sierra 5.3L with dynomax cat back duals and an air raid CAI and a poweraid throttle body spacer. I run 87 octane as 91 plus can be hard to find. what tune do I run I tried 87 Octane tune and gained 3 - 4 MPG and some noticeable power. Tried Diablo tune and mileage was close to the same but way more bottom end. my truck is flex fuel and 6 speed transmission. Any recommendations? Any other things to do when having these mods?
RE: 2009 sierra 5.3l any recommendations for tune with preda
Posted: Mon Apr 18, 2011 11:24 am
if you only use 87 octane gas in the truck, then use the 87 octane tune...
you don't want to use the diablo tune - that tune is made for 91/93 octane gas and it has the timing/spark advance set a lot higher and will cause knock when you get on it...
Posted: Mon Apr 18, 2011 11:33 am
by thunderwolfx
ok so what is the advantage to turning off the dod? also what can i expect from the new 6 speed update and when i update do i have to update everyone in order or just straight to the new update? mine says V9.01? Thanks
Posted: Mon Apr 18, 2011 1:25 pm
turning off the DOD will make it stay in 8 cyl. mode all the time, and a lot of people have found that they actually gain some mileage with it disabled....
all depends on if you do a LOT of highway driving or not...
predators will not be getting any update for tcm/tranny support... they are limited by their amount of memory and storage space...
when tcm/tranny support is finally done and available, it will be an update for the Trinity and new inTune programmer...
Posted: Tue Apr 19, 2011 1:26 am
by thunderwolfx
so the dod off helps mileage if mostly highway or mostly off highway and does it do anything for performance with it turned off?
Posted: Tue Apr 19, 2011 9:36 am
by CANUCKPREDATOR
off highway it helps, on highway its gotta be pretty flat to see any real benefit
Posted: Tue Apr 19, 2011 10:49 am
by thunderwolfx
also updated predator from v9r10 to v9r18t and tried to update to v9r21 and predator says can't downgrade from v9r16 to v9r21. what do i do?
Re: RE: 2009 sierra 5.3l any recommendations for tune with p
Posted: Tue Apr 19, 2011 11:39 am
thunderwolfx wrote:also updated predator from v9r10 to v9r18t and tried to update to v9r21 and predator says can't downgrade from v9r16 to v9r21. what do i do?
Load this, then 9r21.
RE: Re: RE: 2009 sierra 5.3l any recommendations for tune wi
Posted: Tue Apr 19, 2011 5:10 pm
by thunderwolfx
so if you drive back roads all week like gravel etc where your speed varies it should help with the dod off ? i drive 50% gravel 30% highway and the rest town during the week. weekends are pretty much all highway what would you recommend on or off?
Posted: Tue Apr 19, 2011 5:14 pm
if that was my driving scenario, I'd turn it off...
Posted: Tue Apr 19, 2011 6:03 pm
by thunderwolfx
ok so i went to install the two updates and neither of them show up when i try to send them to the tool yet when i check where i saved them they are still there ???
Posted: Tue Apr 19, 2011 6:04 pm
by thunderwolfx
nevermind i got it
Posted: Tue Apr 19, 2011 6:25 pm
by gundog
I disabled the DOD in my 2007 Yukon and have not noticed any difference in my gas mileage. I do feel more comfortable with it disabled as it should will benefit the longevity of the engine, no valves constantly collapsing then reactivating while switching back and forth from 4 to 8 cyl. operation and no chance for brief temperature change in the affected cylinders or parts while deactivated then reactivated, even if for a very brief amount of time.
