Fuel map difference between 93 cai and 91 cai.
Posted: Fri Apr 22, 2011 10:45 am
I installed long tubes on my 2010 challenger rt and then ran some logs while logging AFR with my LM-1 wideband. I had the 92 CAI tune iinstalled
I added between 5% and 7% more fuel to get my AFR around mid 12s.
With the 93 CAI tune and the added fuel, Im seeing ST KNK Retard right after a shift (upwards of 3) and it slowly drops as the rpms rise. then it peaks back up at the next shift.
So I want to go to the 91 CAI tune to see if the ST KNK goes away. I expect I'll have to add more fuel to this as well. Are the WOT fuel maps the same between the 93 CAI and the 91 CAI so all I'll need to do is just add the same 5% to 7% more fuel to the 91 cai tune?
Or will I need to start from scratch and just keep running logs and making adjustments?
Im looking for a starting place as I cant keep making wot runs out there on street....
