08 5.7L Ram-- Transmission not shifting when loading 93 Tune
Posted: Tue Apr 26, 2011 11:30 pm
by robustRed
U7137; 9r11; 2008 Dodge Ram 1500 5.7L
Why is it when after i load the diablo 93 octane tune and drive the truck, it stays in first gear in converter fase and has no power? foot to the floor and the truck goes no where fast; doesent even shift. Please Help
RE: 08 5.7L Ram-- Transmission not shifting when loading 93
Posted: Tue Apr 26, 2011 11:51 pm
by Mike_Levy
Did you screw with the axle ratio setting?
Posted: Wed Apr 27, 2011 10:06 am
by robustRed
No, i never touched that setting. the only settings i went in and changed were; throttle sensitiviity, speed limiter, and rev limiter. and even so after i had the problem i went back and reset all the perameters.
Posted: Wed Apr 27, 2011 6:12 pm
by robustRed
Hey Mike, i just figured out how to solve the issue i am having. For some reason after i install a tune, the communication is cut from the transmission, but to fix this i just disconnected then reconnected the battery cable and the transmisson was working just fine. Im am just stumped on why this happens? any ideas???
Posted: Wed Apr 27, 2011 6:26 pm
disconnecting the battery on these vehicles is the cure all for anything
Re: RE: 08 5.7L Ram-- Transmission not shifting when loading
Posted: Wed Apr 27, 2011 7:12 pm
by Mike_Levy
mikel wrote:disconnecting the battery on these vehicles is the cure all for anything
Wish that was true.
Been weeks and my fuel trims are still all screwed up. Thats okay though, cause I have a transmission sitting in the back and aren't driving anyway.
RE: Re: RE: 08 5.7L Ram-- Transmission not shifting when loa
Posted: Wed Apr 27, 2011 7:27 pm
by robustRed
so do u think there could possibly be a fix to that problem. i got some live data when it happened, and drove it down the street a little way
Posted: Thu Sep 22, 2011 7:16 pm
by SUBLIME51
I had the same problem with my 07 Crarger R/T today after i made the wheels spin to much..I was able to pull off and turn the car off and back on, that setteled the problem temporarly, it came back when I made the wheels spin to much again...There's deffenitly something wrong here....
