2005 chevy Cooling fans staying on
pstrokeranger
Post by pstrokeranger »
Need help. I have a 2005 Chevy with a 5.3L. I have the Preditor U7193 with version 9r11. I am having trouble with the cooling fans running constantly. I had an older version and update to this one hoping this would fix the problem. It didnt. With the programmer removed the fans turn on when they need to. What should I do. Any help would be apreciated. Thanks
CANUCKPREDATOR
RE: 2005 chevy Cooling fans staying on
Post by CANUCKPREDATOR »
Are you running the Diablo tune? they are on quite a bit more than stock.
pstrokeranger
Yes I am. But they are on all the time!
CANUCKPREDATOR
mine are on at 50% speed all the time and % climbs at temp climbs. If you want to change those percentages, go into modify the tune. Not sure if your 2005 is the same as my 2007 but I've got temps and %s and I can adjust them.
pstrokeranger
Ok. I appreciate the help. Ill check and see. Thanks
no.. the older 2005 does not have electronic controlled fans like yours Canuck... there are no fan power percentages to adjust...
you will have 4 temps in there to adjust.. fan 1 off, fan 1 on, fan 2 off, fan 2 on...
with the tune, they're probably set to 189*, 196*, 197*, and 205* right now...
stock settings are way high, at like 220* + for all of 'em
so if you want to change those temps, I would just add another 10* to all 4 of 'em.. 199, 206, 207, and 215...
Return to “Trinity GM Gas”
