2010 Ram 1500 shift point adjustment
Posted: Sat May 07, 2011 9:23 pm
by Firebirdvette
I've got a 2010 Dodge Ram 1500 R/T and wanted to adjust my first gear shift point and for some reason it won't. When in manual mode it forces the shift at 5600rpm regardless of the setting it's on. The only thing setting it higher does is make it shift hard because it hesistates and it feels like it's doing more bad than good.
Also, where is my 2nd to 3rd shift when I'm not in manual mode? Oh, and will there be any future support of an R/T specific transmission since the torque converter is different from the factory?
RE: 2010 Ram 1500 shift point adjustment
Posted: Mon May 09, 2011 10:23 am
I dont think the adjustments work in manual mode.
Posted: Mon May 09, 2011 9:03 pm
by Firebirdvette
They work for every gear but 1st. But before I put my trinity it still force shifted 1st if you waited too long. I guess the Trinity just doesn't override it? Regardless, if the shift points work correctly in drive and not manual mode it really needs to hit 3rd not skip it and go from 2nd to 4th.
Posted: Thu Jun 16, 2011 3:02 pm
by RamTex
I have a 2009 Ram 5.7 and my truck wont shift into any gear if set over 6k by trinity and only shifts at 5.7k actual rpm's at WOT. Ive reloaded tune several times. Also at WOT with esp off it wont shift into any gears i have to back off the throttle then it shifts. All of this is on the current update...
It seemed to work better with previous updates but only mediocre at best. Before it would shift with or with out esp on at WOT but would not shift past 6.1k set by trinity 1st to 2nd gear. But actual rpm's were 5.9k and from 2nd to 3rd would not shift past 6k set by trinity actual rpms 5.7k.
Any info would be great.
