2005 Dodge 2500 Diesel idle fluctuatung
mjensen
Post by mjensen »
I am having an issue when I first start my truck. The idle will fluctuate up and down +/- 100 rpm and my battery gauge reads low. After about 2 minutes the idle will settle and the battery gauge will read properly. It almost seems like the ECU is stuck in open loop mode. After the 2 minutes the truck runs fine and has no other issues. It didn't start until I loaded the predator to the truck. Any thoughts on this?
RE: 2005 Dodge 2500 Diesel idle fluctuatung
it will always start in open loop if cold, it takes some time to heat the O2s to go into closed loop.
Tahnks
