Transfer DSH file to TDS file
Posted: Tue May 17, 2011 4:44 pm
by erich20
Is it possible to transfer .dsh file (data viewer dashboard) into .tds (trinity layout) file to monitor more parameter directly on the trinity. For exemple i can monitor transmission oil temperature with pc and data viewer connect to the car both not with the trinity only. This is for a 2009 hemi ram.
RE: Transfer DSH file to TDS file
Posted: Tue May 17, 2011 4:45 pm
No....they are different types of files entirely.
Posted: Tue May 17, 2011 4:50 pm
by erich20
Is it possible to had some pid to monitor for exemple transmission oil temp directly on trinity.
Posted: Tue May 17, 2011 4:57 pm
by erich20
Why I can monitor transmission oil temp with data viewer and PC but not with trinity.
Posted: Tue May 17, 2011 5:07 pm
by jimb
When using DV, it uses it's own PID database. Whereas Trinity contains only a compiled sub-set of PIDs.
Posted: Tue May 17, 2011 5:17 pm
by erich20
Do you know if the transmission oil temp and other pid will be add in the list or if a program will be create to modify this database on the trinity by the user.
