Brakes lights come on after tire size is put in
VENSION
Post by VENSION »
The part # u7194
Revision is v.9r22
The vechicle is a 2007 chevy silverodo pick up
The tire size is 265/70R17
The problem that I am having is that after installing the modified tune for the correct tire size 31.5" and the performance tune the trucks warning lights for the brakes and abs system comes on . So far no one at Diablosport can come up with a correct answer to the problem.
Should I just return the programmer and buy someone elses????
Help, Vension
[/b]
TMACCHEVY
RE: Brakes lights come on after tire size is put in
Post by TMACCHEVY »
Im having the same issue!!! Still havent found a answer yet.
Are you also disabling the speed limiter when you do this?
steveb
Post by steveb »
My traction control light comes on, when I make a turn, and I could feel the front brakes come on, the computer think s its slipping
07chevyvortecmax
Post by 07chevyvortecmax »
I have the same issue, I have an 07 vortecmax 6.0L chev. Put on both the 87 and diablo tune. Never set my tire size until I read some forums. Since I'm a mechanic I put on my Solus pro Snap-on scanner and my front speed sensors were at 103 kmh and the rear sensors were at 112kmh. The abs code is a C0245. I then re-installled the tune with the 275/55R20 tire size and went for a drive with the same result. I did have the max speed turned off on the second tune. Upon re-installing the stock tune all my speed sensors were at 107kmh.
steveb
Post by steveb »
SO DID TO SOLVE THE PROBLEM,? WHAT CAN I DO
try leaving the speed limiter ON for now.
jestes
Post by jestes »
My brake light and ABS light are both on after tuning and tire adjustment. any fix yet?
post up backup and last tune written please
jestes
Post by jestes »
87 tune, modified tire size to 285/70/17
I need the actual tune file as exported formt he Predator.
jomeara10
Re: RE: Brakes lights come on after tire size is put in
Post by jomeara10 »
steveb wrote:My traction control light comes on, when I make a turn, and I could feel the front brakes come on, the computer think s its slipping
I am having the same issue. In a previous thread, Mikel said it was an issue with lifted trucks that there is no fix for.
2010 Chevy 6.2L
K&N CAI
6" RCD lift w/35" Nitto Grapplers
2008Silvy
RE: Re: RE: Brakes lights come on after tire size is put in
Post by 2008Silvy »
Lots of people have the same problem with trucks that aren't lifted.
jomeara10
Re: RE: Re: RE: Brakes lights come on after tire size is put
Post by jomeara10 »
2008Silvy wrote:Lots of people have the same problem with trucks that aren't lifted.
My point exactly. I find it hard to believe that the lifted trucks and non-lifted trucks have seperate issues when they are doing the exact same thing.
2010 Chevy 6.2L
K&N CAI
blackout07
RE: Re: RE: Re: RE: Brakes lights come on after tire size is
Post by blackout07 »
My truck is lifted with 35's and 4.88 gears and I have no lights.
