LTFT and PE Adjustment
Posted: Wed May 25, 2011 10:18 pm
I have a 99 corvette with cone filter, cat back, and predator tune. The predator is U7198 with 2.13 on it. I have a OBD II program that i can log with. My predator can't record. My original LTFTs on a log would fluctuate between +7 to +15. I adjusted the slope by -8 and did a check of LTFT and at 70mph in 6th gear1830rpm they were at about +3 but at 55mph in 5th gear at 2000rpm they were at -1.6, and at idle they are at -10.
Question that i have is LTFT at idle of -10 good, bad, or doesn't matter?
Does the gear that is used make a difference even if the rpm is close?
Additional question that i have is regarding PE adjusting. I read on 06MonteSS's sticky that you adjust the PE by half of the LTFT value. So my understanding is that if i adjusted my LTFT by -8 that i should adjust my PE by -4? Also, my car does not have the ability to read AFR.
I appreciate the response. Thanks
