Page 1 of 2
Trinity - Synthesized Boost not working
Posted: Mon May 30, 2011 1:20 pm
by raffin
I have a 2006 Charger SRT8 with a Magnacharger installed. Trinity has the most current update. It does monitor Baro and MAP PIDs, but the Synthesized Boost PID always reads zero (In monitor mode). The MAP PID does show increasing boost with increasing RPM and Baro minus MAP gives around the expected boost value. I currently have the following gauges configured on the dashboard: Intake Charge Temp, Baro, MAP, and Synthesized Boost.
What do I need to do to get it working?
RE: Trinity - Synthesized Boost not working
Posted: Tue May 31, 2011 9:32 am
Can you post a log?
Re: RE: Trinity - Synthesized Boost not working
Posted: Tue May 31, 2011 1:43 pm
by raffin
mikel wrote:Can you post a log?
Sure, what PIDs do I need to log?
RE: Re: RE: Trinity - Synthesized Boost not working
Posted: Thu Jun 02, 2011 7:35 pm
by jimb
Log MAP, BARO and RPM. Also, Make sure you have 1r08a of dcx_gas.
Posted: Fri Jun 10, 2011 12:21 am
by raffin
Here's a short log file. It includes RPM, BARO, and MAP among other PIDs.
Posted: Fri Jun 10, 2011 10:29 pm
by jimb
According to the log, Synth Boost should show around 44 kPa max before MAP quickly drops off.
Posted: Sun Jun 12, 2011 11:51 pm
by raffin
jimb wrote:According to the log, Synth Boost should show around 44 kPa max before MAP quickly drops off.
"Should" is the operative word here. It stays rock solid on 0.00. I did change it to read PSI instead of KPa, but I wouldn't think that would make any difference.
Posted: Mon Jun 13, 2011 10:30 am
Are you on the latest 1r08b?
Posted: Mon Jun 13, 2011 7:31 pm
by raffin
I'm on 1r08a. I tried to get the Trinity to update, but it isn't attempting to update when I run DSDL 2.2.2.6. The Trinity is registered and did download 1r08a when it was connected the first time. It is connecting to the computer properly.
Posted: Sun Jun 19, 2011 10:11 pm
by raffin
OK brain fart on my part. I forgot to restore the original tune before updating. It's updated now and I'll see if the boost gauge works tomorrow.
Posted: Tue Jun 21, 2011 3:05 pm
by raffin
After updating to 1r08b synth boost works perfectly, thanks!
Posted: Tue Jun 21, 2011 3:15 pm
awesome.
Posted: Sun Dec 11, 2011 9:32 pm
by Speedy!
I'm on 1r08c and the boost pid maxes out at 2.90. I set the range at 0-20. Any thoughts?
However when I go back and review the log in DataViewer I see Map and Baro are correct and doing the math the PSI is right. It's just like the display isn't showing it properly.
Also, any reason we can't have a "boost" pid on Data Viewer? Seems it'd be easy for that program to do the maths for us.
Posted: Mon Dec 12, 2011 11:02 am
hmmm...question...what if you use a different type of gauge for the boost pid?
Posted: Mon Dec 12, 2011 1:01 pm
by Speedy!
mikel wrote:hmmm...question...what if you use a different type of gauge for the boost pid?
I'll try that and report back. Current gauge is a horizontal slider.
