Page 1 of 2
loading custom tunes
Posted: Sun Jun 05, 2011 1:31 pm
by hemiram07
the custom tunes are not loading properly.even though the predator says tune was installed nothing is changing on my trucks computer.the only tune it will accept is the canned tunes.when i sent the last written tunes to the cmr tuner he said none of the tunes he sent took to the trucks computer.anyone ever have this problem or know how to fix it.
U7137 9r12. 2007 ram laramie
RE: loading custom tunes
Posted: Sun Jun 05, 2011 4:29 pm
by brandy16
When you loaded the custom tune what did the predator have as the last tune written
Posted: Sun Jun 05, 2011 4:39 pm
by hemiram07
the 1st time a 93 perf. tune.after that it had custom tunes on it but like i told the cmr it doesn't feel right
Posted: Mon Jun 06, 2011 10:06 am
by HESCO
you have to be sure the original tune is loaded into the predator correctly. When you "send tune file to predator" it will ask you to browse for your original tune file, you MUST navigate to the area where you saved the original tune file and double click on it....if you let the software load it automaticaly it may not work correctly. My first time using a predator I had trouble with that step. even though the predator will tell you the tune is loaded into the vehicle it won't make any changes becouse the original tune is not loaded correctly.
so I guess "get the original tune file from the tool" and save it to your pc. then load the custom tune and it will ask you for the original file then....navigate to the file and select it and you should be good to go.
Posted: Tue Jun 07, 2011 12:20 am
by hemiram07
yea i tried that several times . i even put my truck to stock then put the canned 93 tune in which worked fine.then went back and downloaded the custom tune again to the predator but it still didnt take.
Posted: Tue Jun 07, 2011 10:31 am
Are you getting nay errors on the dsdownloader?
Posted: Tue Jun 07, 2011 3:32 pm
by hemiram07
no errors at all.the canned tunes load but the custom tunes will not.the only thing he noticed was if i modified the custom tune .for example i shut the mds off,tire size and throttle boost to 15% that was the only thing to change.i even tried loading the custom tune without modifying and still nothing at all.
Posted: Tue Jun 07, 2011 4:53 pm
there must be some messgae that comes up when you try to load the canned tunes...?
Posted: Tue Jun 07, 2011 5:47 pm
by hemiram07
tune was uploaded successfully
Posted: Tue Jun 07, 2011 6:23 pm
but what does it day when you go to load it to the car?
Posted: Tue Jun 07, 2011 7:02 pm
by hemiram07
the custom tune was successfully loaded you may unplug the predator now.
Posted: Wed Jun 08, 2011 1:00 pm
then its all good my friend....???
Posted: Wed Jun 08, 2011 1:29 pm
by HESCO
are you sure the custom tune is really a custom tune? post up your original tune and custom tune and we will have a look at it.
if you didn't get the original file loaded onto the predator correctly when you sent the custom tune to the predator it will show that the tune was loaded properly into the vehicle but WON'T make any changes to the vehicle.
Posted: Thu Jun 09, 2011 10:37 pm
by hemiram07
HESCO wrote:are you sure the custom tune is really a custom tune? post up your original tune and custom tune and we will have a look at it.
Posted: Thu Jun 09, 2011 10:41 pm
by hemiram07
