hi i got the trinity for one of mi costumers
i did the update procedure and got the las file
and could not program it i read the original file but i don now if y must post it here or wat do you recomend help me out
2011 sierra denalli 6.2
serial number 6jw4g0a
RE: 2011 sierra denalli 6.2
it will not read the stock tune from the truck?
What is the error?
What is the error?
yes it does read the original file but it says the file i need for the truck is not suported yet mi truck bin is 3gtp29e25bg255913 and saved clid 639835639696
do you want me to e mail the file??
i did down load it from the trinity to mi lap top
firmware version in the trinity v.1r08
by the way they are flex fuel
ok, so since it DOES read and save a copy of the original backup stock tune file, use the dsdownloader to export a copy of your orignal backup tune file and post it up here...
support for your enigne calibration will need to be added to an update...
hi here is the file i help i did it right
- PCM_639835639696denalli.grg
- archivo de denalli 2011 6.2 flex
- (67.91 KiB) Downloaded 123 times
here is the update with support for your vehicle.
- u7194-9t24a.crom
- (1.55 MiB) Downloaded 121 times
