U7134 Autoconnects then tool is not found
mastaof420
Post by mastaof420 »
Hey I'm trying to move a tune file from my pc to my dsp
I've been using it regularly with no problems whatsoever
but today when I plugged the tool in. It autoconnects but takes a very long time, then when I click to send file to the tool it says waiting for transfer. Then it times out and says tool not found. I updated the ds downloader and it didn't help. It worked fine last week. I also tried using 2 different known good cables with no luck. Can somebody steer me in the right direction.
RE: U7134 Autoconnects then tool is not found
sounds like a possible cable issue....try moving it around or try a different USB port onthe PC.
mastaof420
ya that was one of the first things I tried. I also tried unplugging my usb mouse. And using a second cable.
mastaof420
nevermind.........I unistalled my cable driver then reinstalled. I think it might have been because I used a cable that I dont normally use with the dsp. Then switched back to the original one.
yup, that can do it ;)
JustinJMB
Re: U7134 Autoconnects then tool is not found
Post by JustinJMB »
Im also having trouble with my U7134. It has connected to my PC befo, but now nothing. This is on three different computers as well. Each one that the tool has worked with previously arent able to find it.
bad cable perhaps?
