HELP! My 2011 Camaro is a brick!
TDC#2
Post by TDC#2 »
I bought a Predator from someone online (I'll deal with him later), tried to load it and now my car won't start. This is exactly what I did.
1. Plugged in the Predator
2. Turn the key to ON
3. predator did something for a while
4. I checked the menu, did not see normal options
5. unplugged it
6. plugged it back in
7. checked last tune
8. tried to reset to stock
9. Predator verified it was not licensed for my vehicle
10. reset and allowed me to unplug
11. Car won't start - display said something about the engine not having enough power?
12. Pulled the #5 and #20 fuses
13. Got on here
Help. It's a 2011 Camaro SS with the L99
TDC#2
RE: HELP! My 2011 Camaro is a brick!
Post by TDC#2 »
Ok, it will start now that I let it sit and replaced the fuses, but the CEL is on...
make sure that predator has the latest/newest available revision update installed on it...
what's the trouble code you're getting that's causing the CEL?? what mods are done to the car??
"9. Predator verified it was not licensed for my vehicle " well, then this means it's still locked to the other persons vehicle...
power up the predator and go to options - show last tune written... what does it say??
Return to “General Support”
