02 mustang gt speedo help
I put 4.10 gears in my mustang gt an I bought a predator tuner from my friend need help with fixing my mph says in the manual for 4.10 it should be 4.1 but I don't see it on the tuner
RE: 02 mustang gt speedo help
4.10s were installed in my 2003GT. On my tuner my setting was 4.09 .Thats the right setting and my car runs perfect. Bear in mind if you`ve changed the tyre/wheel diameter then you`ll have to adjust your speedo using the `modifying parameters` part of the tune. If ou haven`t changed wheel/tyre size then no ned to do anything.
Formula for working it out;
Tyre Size Tyre revs per mile = To properly calculate the revs per mile you will have to measure your rim and tyres diameter (in inches) and put it into this formula :20168 divided by tyre diameter = revs per mile Ex. 20168 / 26 = 775
Ok I got it thanks man
