Terrible Mileage---Can't Revert to Older CROM U7165
Posted: Mon Jun 20, 2011 7:56 am
by Dawgman
Well, I have tried all tunes on the new update, and love the power on the extreme tune. However, my mileage has suffered and I'm a very conservative driver (most of the time). I have lost an average of 2-3 mpgs on all tunes.
I received many different tunes in the past to help with my situations and tried to revert back to 8r20. When trying to upload the CROM to the tool, I got an error message....."Can't downgrade pcm 6_0_ below 9r13".
Is there a way to get around this, or can I get a better "performance" tune?
Eric D
2005 F-250
U7165
Calid-VXCF4D3
144,000 Miles
AFE Intake
AFE 4" Exhaust
Stock Wheels/Tires
RE: Terrible Mileage---Can
Posted: Mon Jun 20, 2011 10:35 am
by frankl
You wont be able to downgrade, Send us a copy of the last tune written and we can take a look at it. Have you been up on your maintenance? Clean air filter, stuff like that?
Posted: Mon Jun 20, 2011 10:59 am
by Buck02
Emailed you 2 new files. You should see a huge gain. Keep me posted.
Posted: Mon Jun 20, 2011 11:07 am
by ProEMTPFF
Huge gain in economy? I'll give it a test run.
Posted: Mon Jun 20, 2011 11:10 am
by Dawgman
Thanks Buck! I'll give both a try. As far as regular maintenance go, the answer is yes. Always on top of it.
Eric D
Posted: Fri Jun 24, 2011 11:18 pm
by Mutts
Buck I sent you a pm but if you don't get it could you send me the new tunes as well. My cal is vxbc9f2 for th u7165 v. 9r13 2004 f-250 6.0 diesel with the icp sensor on the valve cover and now running a 4 in turbo back no cat rbp exhaust system. Tell me If I need to up load my tune to you.
Posted: Mon Jul 18, 2011 8:41 am
by Dawgman
Buck,
Over the last month or so I have tried both tunes that you sent me. Driving conditions were fairly consistant, and all mileage figures were hand calculated. So, here is the scoop:
Custome Tune 1--2 fill ups with a mpg average of 17.3.
Custome Tune 2--2 fill ups with a mpg average of 14.3.
Love the power of the new extreme tune, but like I said, my mileage suffered (average of 15.2).
The power for the custome tune is OK, and the shifting points are great. I will be using Custome Tune 1 for now.
Thanks again Buck!
Eric D
Posted: Wed Aug 17, 2011 6:22 pm
by mauere1
Buck, can I get a copy of the tune 1 mentioned above?
Posted: Mon Aug 22, 2011 10:32 am
by moparmcal
Hi Buck, I've recently downloaded the 9r14 tune for my predator and I'm having a difficult time getting mileage also (driving like there is an egg under the throttle). Could I possibly get the tune #1 mention above?
Mark
U7165
9r14
05 F250 6.0L
Posted: Tue Nov 08, 2011 6:08 pm
by The_Owl
[quote="moparmcal"]Hi Buck, IHi Buck,
I'm a new customer,I have v.9r13 on my tool and would LOVE to get the mileage listed above (below for reference)
"Custom Tune 1--2 fill ups with a mpg average of 17.3. "
If you would email a copy to me I'd be eternally grateful. Do I need to upgrade to v9r14 first to use them and restore original tune before the upgrade?
I'm using the 60 HP Economy tune now and I don't really notice much of any difference except mileage isn't as good as before.
Jerry P
The_Owl
9r13
2006 F250 6.0L
Posted: Tue Nov 08, 2011 6:29 pm
I would try the 9r14 first, yes. restore to stock, then update, then load the new tunes from 9r14.
Posted: Thu Dec 22, 2011 8:46 pm
by hard2handle
I also have a 6.0l with 9R14 and I do not like the shifting at around 4000-5000rpm shes got 230k on her and I do not like her goin that high, and my mileage is not great after update. I have new dealer flash also got it like 6 months ago and when i put 9R13 in it had like no power. So I updated to 9R14 and I thought it does not have the same fuel mileage or power as before update. I have went back to stock a coulpe of times to see if it would help...but it never did. If there is a better file like #1 mentioned above I would be grateful. I also keep up with maintenance 4" ex. turbo back, no cat, no new head studs and I need something to keep egts down until egr delete.
Brad
Много пол
Posted: Mon Dec 26, 2011 2:49 pm
by grarrixNox
Хороший у ваÑ
