2009 Chevy Silverado, COMPLETE Electrical Shutdown
Posted: Thu Jun 23, 2011 10:46 am
Need help -
I have a 2009 Chevy Silverado 1500LTZ with the 6.2L V8. Currently I'm running the Predator U7194 on the high octane tune. Recently, my truck will on occasion stall when I try to start it. This is not like it's a dead battery though, it's like the entire computer system is shutting off my truck. Then last night, things took a turn for the worse. I was driving to a friends place, going about 10 mph and about to turn on his street, when my truck had a complete shutdown. Like someone pulled the plug on my truck. Absolutely no electronics working, turn the key and nothing happens, no lights, nothing. It also happened to be in the 5th ward of Houston, which for those of you unfamiliar is arguably THE worst area of Houston to be in, especially for a white boy.
Bottom line is when I finally hooked up the predator the first time, with my door closed in the truck, the screen just started flashing like the programmer had crapped out on me. Then after a while of messing with it, I plugged in the programmer with the door open, and it worked. I was able to clear the error code and start my truck, even though it was hesitant to start the first time like I have described above. I did not write down the error code for the sake of getting the F**K out of the area I was in and doing it quickly, but if you guys have any suggestions I would greatly appreciate it. I would like to keep using my programmer because of the gains in HP and mpg's, but it's not worth breaking down again in the ghetto's of Houston.
Please, help me out here. I don't know what revision I have on the programmer right now, but it was the latest one as of 4/27/11, according to Vas.
