calid #12250053AJ
# on sticker on back is 142243-u7130
codes with no programming and stock tune re-installed from tuner:
turbocharger over boost-manifold pressure reading above turbocharger overboost limit detected.
manifold absolute pressure sensor input below minimum acceptable voltage
cooling fan speed
voltage 1 circuit low
with any programming I get all the above plus
control module programmer, control module programmer error/not programmed.
truck runs good, I know I have a vacuum leak cause I hear the buzz at idle, please help
I use to think my CEL light was broke cause I have never seen it even when my transmission finally scattered, Thanks Tony
oops,
sorry.
2003 SO engine 250hp Manuf. 04/03, afe mega intake MBRP 4", all guages all normer egts etc trans temps A-ok boost not erratic I just don't get it
after almost 3 years on extreme tune received 1st "code
RE: after almost 3 years on extreme tune received 1st "
mod please move to predatore forum sorry
2003 SO 250hp, u7130/puck, goerend built auto, all guages etc.
tough to say, but it sounds like the truck may have developed an issue, possibly electrical.
Id have it checked out by a reputable dealer.
