trinity shutting off/freezing due to vibrations?
alittletippy
OK had my trinity due weird stuff on my way to work. It shut itself off and on two or three times and froze once. I unplugged it and plugged it back in and when I went into monitoring and chose my loadout it told me to turn engine on although car was already on. I hit proceed and everything worked fine. My question is could vibrations have caused this? I recently did work to the car, a dodge neon with srt4 motor swap, which included adding a solid tranny mount so the car has all solid mounts. This increased my vibes. I have the trinity mounted in a gauge pod with a custom made mount. A milled piece of metal with the flexable rod from the original window mount. Any help would be appreciated.
RE: trinity shutting off/freezing due to vibrations?
Check the connection on the bottom of the Trinity and remove some material from the case of the Trinity if it is really tight.
