LTFT Question
Rnhall
LTFT Question
Post by Rnhall »
I keep reading that when checking LTFT's you should be in the 2000 RPM range and I've also read you should be check LTFT's at cruise.
At 75 MPH my Vette is turning 1700 RPM's. So is it best to check LTFT's st cruise or drop down two gears and chack at 2000 RPM's?
Ralph :?:
CANUCKPREDATOR
RE: LTFT Question
Post by CANUCKPREDATOR »
yeah cruise at 2000ish, what ever gear it takes. Or cruise at 2000 and knock some cobwebs out of the car ;)
RE: LTFT Question
you want to be at 1800 ideally... 2000 at the most...
so drop down a gear....
Rnhall
Post by Rnhall »
What would you expect to see when looking at the LTFT's at say 1600 RPM's Vs. 2000 RPM's?
Rally2SS
Post by Rally2SS »
Rnhall wrote:What would you expect to see when looking at the LTFT's at say 1600 RPM's Vs. 2000 RPM's?
UNusable information as far as DSlogRedux is concerned...!?
Grumpy_Aero_Guy
Post by Grumpy_Aero_Guy »
yeah, dslogredux allows you to choose an rpm range that corresponds, as best possible, to your cruise RPMS --- 1800 to 2200 rpm in various increments thereof.
1600 is too low. Drop a gear and do around 2000 if you can.
DSLogRedux.com
Jruss
Post by Jruss »
I'm in the same boat. If I'm in 6th gear with my Corvette I would have to cruise at 82 MPH to show 1800 RPM's
Florida Highway patrol doesn't think kindly of this! :x
2006 Victory Red 3LT A6, Magnetic Ride, Corsa Sports and Hall Tech Stinger.
Rally2SS
Post by Rally2SS »
Feelin' a bit under-geared, here...70 @ 1800 :(
like we've been saying - don't do it in 6th gear! drop down a gear...
Jruss
Post by Jruss »
Rally2SS wrote:Feelin' a bit under-geared, here...70 @ 1800 :(
That is because I'm running with a 2:56 rear drive differential.
