Quick Wheel Question
Posted: Fri Aug 10, 2007 5:37 pm
by nofinga911
ok i plugged my predator into my truck...then modified my tire and rim info...but how come when i went back to check and make sure my wheel and tire info was still there, it reset back to what was originally there as if i didnt modify it...now i installed the tune after i modified the wheel and rim info but i dont know if it got programmed in...
Posted: Fri Aug 10, 2007 10:08 pm
by nofinga911
Did it get programmed in? Im assuming it did because while i was driving to my girlfriends house i had to be going about 70 and my speedo said i was going 12. Does anybody have an idea of what went wrong????
Posted: Sat Aug 11, 2007 3:49 pm
by nofinga911
please can someone help....my speedometer is all messed up...the highest it goes is 12mph even if im going like 70mph...help please
Posted: Sat Aug 11, 2007 11:04 pm
What year is the truck?
Did you enter the factory tire size first, followed by the actual (new) tire size?
Posted: Sun Aug 12, 2007 2:44 am
by nofinga911
mikel wrote:What year is the truck?
its an 07' escalade ext....i entered the aftermarket tire size and then prog. my truck....you mean first program it with the stock and then program it with the aftermarket? i dont understand?
Posted: Sun Aug 12, 2007 9:56 am
by BamBam
Read the install instructions and it will guild you thru the tire change. Yes, if I am correct, you MUST enter the original factory tire size FOLLOWED by the NEW aftermarket size. Try that.
Posted: Sun Aug 12, 2007 12:27 pm
OK, thats why I asked...on the 07 trucks, you do not need to enter the stock tire size.
I do recall that one of the older revisions had an issue with adjusting the tire size properly.
Make sure the tool is on the latest revision.
Posted: Sun Aug 12, 2007 1:47 pm
by nofinga911
mikel wrote:OK, thats why I asked...on the 07 trucks, you do not need to enter the stock tire size.
ok i will check it now...but to make sure i am doing everything correctly...i plug in the predator adjust the wheel size (not by tire size) but by the first option that asks for the 2 measurements and then i install the tune...correct?
