'06 C6 Vette - adjust tire size
toadzca
Post by toadzca »
OK wondering if I can get a Predator to adjust tire size in a '06 C6 Vette when running it at the drag strip then using this tuner to change back when put street tires/sizes back on. There is already a custom tune in this car & all I want to do is adjust the tire size on it. Can I do this with a stock Predator or do I have to have a second tune written including the change in tire size?
RE:
Yes, you can use the predators 'modify stock tune' option to change just the tire size of the currently installed custom tune.
Rally2SS
RE:
Post by Rally2SS »
Monte, is that true if the custom tune is not CMR??
RE:
Ummm....yes.
I'm not Lew but I'm pretty sure I know better than he would ;)
RE:
AAHAHAHA!!! ^ ^ ^
yes Rally.. because the tool will save that tune on your pcm as the "original backup" stock tune in the tool... so if you go to "Modify Stock Tune" like Mikel says, you can make a change to it and then reinstall it... and it will install your custom tune (which is saved as the stock tune in the tool) with your change made to it...
Rally2SS
RE:
Post by Rally2SS »
OOPS! Sorry Mike! :oops:
I'm just used to Lew responding first :twisted:
RE:
:lol:
