U7194 for 07 Suburban 5.3 need gear change map
bigkevssf
Post by bigkevssf »
I have a 2007 Suburban 4x4 1500 z71 with 5.3 liter
K&N cold air
magnaflow 19" can cat back
305 60 20 tires
4.88 gears
The speedometer is wrong and I need a new map, please. Can you make me one for the 87 octane and also the 91 with the 4.88 gears?
Predator U7194
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM3 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '2130755652'.
Part number = 'u7194'.
CROM version = 'u7194-9r23 05/24/2011 04:11:06 PM boot3'.
Vehicle VIN = '3GNFK16357G285318'.
Vehicle Calibration = '12614088'.
Original backup SAVED.
Tool is Married TRUE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are NOT supported.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool SUPPORTS multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 1
Marriage VIN : 3GNFK16357G285318
Tool ID :
Desc :
PCM : 614088614094
Multi ECU Tuning : 1
Name: PCM, TuneID: Diablo Tune, Modified: yes, Lock: No, Erased: No
Server:
PCM_614088614094_Diablo_Tune_modified.grg
I changed the tire size and speed limiter I think.
(4.25 KiB) Downloaded 120 times
RE: U7194 for 07 Suburban 5.3 need gear change map
got your email, we'll get the tune out to you asap.
bigkevssf
Post by bigkevssf »
Thanks, Mike! That was quick. Now the girlfriend can drive and not think she is going 100mph all the time! lol
Return to “Trinity GM Gas”
