C6 MN6 93 Octane
Posted: Sun Aug 12, 2007 9:08 pm
by LostAngel
Hi I just got my tuner, and was wondering if my logs look ok. For some reason i'm only able to get a few minutes following the stickies instructions. I noticed that not all of my 'Knock Retard' is 0's...is that bad? The min of KR is 0...max is 10.2. I am running the 93 octane tune...and run 93 octane.
Attached is my logs...this was done in 5th and 6th gear.
Should I perhaps be going off of whatever my logs should say from first gear up until 6th from 0 to 65...with a few seconds of WOT (8 seconds)?
RE: C6 MN6 93 Octane
Posted: Sun Aug 12, 2007 9:44 pm
yeah, the short data log is a known issue for your Vette / Predator.
you have a lot of KR... especially throughout one of those whole WOT runs... yeah, that's not good. what brand of gas do you use?? at at 100% throttle position, the log is only showing 1,3xx rpms????
your normal cruise/driving ltft's are at -5.xxx... so you should adjust the injector slope to be +5%.
Posted: Sun Aug 12, 2007 9:47 pm
by LostAngel
Sheetz gas...93 octane. The WOT run was done prolly in 5th or 6th gear...so yeah the rpms would be low....would that kind of WOT at such a high gear at low rpms cause that much KR? Also would fixing my LTFT's help the KR?
btw: I also have the Vararam Intake and TB Spacer as well.
Posted: Mon Aug 13, 2007 7:23 am
by LostAngel
Here are two more logs I took today...I forgot to put it in Competition Driving Mode (No Traction Control) in the 1st_run in this post here...so maybe that accounts for the knock in the first second or so. These numbers seem to be a little better KR wise than my first I posted last night...the max is only 6.xx in my 1st_run in this post....it was mostly WOT. The 2nd_run is mostly cruising with a little WOT.
Would you mind looking at these too 06MonteSS? I also included AFR in these runs...not sure how I forgot to before.
Re: RE: C6 MN6 93 Octane
Posted: Mon Aug 13, 2007 8:47 am
LostAngel wrote:Sheetz gas...93 octane. The WOT run was done prolly in 5th or 6th gear...so yeah the rpms would be low....would that kind of WOT at such a high gear at low rpms cause that much KR? Also would fixing my LTFT's help the KR?
yes, if you're in that high of a gear, and floor it at that low of an rpm, you will get a lot of KR 'cuz you're bogging down the engine.
and yes, getting the fuel trims in order by adjusting the injector slope will help.
see if you can get some Mobil, Exxon, Sunoco, Amoco, or BP 93 octane gas. That will likely help with the KR issues as well. I know it did for me. I used to use Shell 93 which I thought was supposed to be good, but after speaking with the fine folks here at Diablosport, I found out that was not the case. After switching to Mobil 93 a while ago, a lot of the KR I used to get is gone.
RE: Re: RE: C6 MN6 93 Octane
Posted: Mon Aug 13, 2007 8:49 am
looking at the logs now... please hold....
are you using the new 3.1 dataviewer??? I ask because your WOT AFR values are 17, 18+ - when they should be in the 12's... there's a known issue I found in the 3.1 dataviewer that does this when saving out the log to a .csv file.
Can you post or send me the actual .log file so I can use it in the 3.0 viewer I have?? thanks.... email to: lewis DOT eaton AT gmail DOT com
please hold... more updates to come...
:lol:
Posted: Mon Aug 13, 2007 9:01 am
by LostAngel
I just sent you an email with the raw logs...thank you so much!
yes I am using 3.1
Posted: Mon Aug 13, 2007 9:14 am
k... got it, thanks...
those are still showing average ltft's of -5.xxx... so, we need to adjust the injector slope.
set the injector slope to +5%. and also set both rpm ranges in the PE to +5%. We want to add fuel to the PE right now so that you stay safe - 'cuz by setting the injector slope positive, we're telling the ECM that your injectors are bigger and to spray less fuel. And if they're spraying less fuel, we don't want to get too lean when you go WOT and cause any issues. So we'll pad the PE for now and re-adjust it once we see the normal driving ltft's are in range.
drive for about 30 miles or so, then do another log and let's see where the ltft numbers and WOT O2/AFR numbers are at. If the ltft's are all set, then we'll adjust the PE fueling.
Posted: Mon Aug 13, 2007 9:17 am
by LostAngel
Alright, I wont be able to until I get out of work at 5:00 EST...i'll do it as soon as I get out, and hopefully by 6:00 - 6:30 ill have the logs sent to you. Now once I update this tune, and drive for 30 minutes...do you want to see me cruising? Or WOT runs?
Thank you so much for this help...based on the KR in my logs, I havent hurt my engine at all have I?
Posted: Mon Aug 13, 2007 9:20 am
just edited my post above:
"set the injector slope to +5%. and also set both rpm ranges in the PE to +5%. We want to add fuel to the PE right now so that you stay safe - 'cuz by setting the injector slope positive, we're telling the ECM that your injectors are bigger and to spray less fuel. And if they're spraying less fuel, we don't want to get too lean when you go WOT and cause any issues. So we'll pad the PE for now and re-adjust it once we see the normal driving ltft's are in range."
so you want to adjust both the injector slope and the PE ranges this time around.
since your logs are short with your vette/predator... can you do 2 for me? have 1 log with normal driving/cruise, and 1 log with some WOT runs.
Posted: Mon Aug 13, 2007 9:35 am
by LostAngel
Alright, so I will set the injector slope + 5...and the PE to +5....and do one cruising run and one WOT run...correct?
Posted: Mon Aug 13, 2007 9:46 am
yes sir...
thanks!
-Lew
Posted: Mon Aug 13, 2007 9:59 am
by LostAngel
thanks lew! Hopefully you will be online once my logs are done!
Posted: Mon Aug 13, 2007 10:26 am
I'm on EST as well - where are you located???
I'll be here at work until 4:15-ish... then I won't be online until about 9pm tonight - so if I miss ya, I'll catch up with ya then...
email me your IM screenname if you have one...
Posted: Mon Aug 13, 2007 10:38 am
by LostAngel
Lew,
9PM will be fine with me...you just messaged me on yahoo...but stopped talking after I said hi.
I am located just south of Erie PA.
