Logging & Modifying Performance Tune on the Dyno
Posted: Fri Aug 05, 2011 2:03 pm
by Scorpion
Is this advisable or waste of money?
Any suggestions for this?
I have my LTFTs dialed in but I want to adjust other parameters.
RE: Logging & Modifying Performance Tune on the Dyno
Posted: Fri Aug 05, 2011 2:12 pm
no harm in dialing it in in a controlled environment to ensure all is well
Posted: Fri Aug 05, 2011 2:44 pm
by Scorpion
Thanks Mike!
So I would do the same logging as I have done before but now I can get a good WOT run in without heading off to jail
and getting my Corvette impounded.
I suppose that after my logging and uploading to my PC, DSLogRedux will analyze my readings and suggest lots of changes
Posted: Mon Aug 08, 2011 9:49 am
by 06MonteSS
not for your 04 it won't... you can't log the AFR parameter on your car with that predator...
see what it's running for an AFR while using a wideband o2 sensor on the dyno...
