C6 LTFT Question using 7194 and the new update 8r07
I have a 2006 C6 with the A6. I logged data with my laptop (Diablo only does about a minute of logging)
After Logging about 50 minutes of data I have 216K lines of data in Excel. It took a while for the macros to run. After running them I now have almost 93,000 lines of data.
Now when I do my LTFT Average there is over a little over a 1 difference between LTFT Bank 1 and Bank 2. 4.08 to a 2.97
Should I use the average of the 2? I don't think there was a setting for each bank when I looked.
Would anyone with a little more experience like to take a look at my file to see if I did it right?
My 02 seems way out of range also. The average is .508 and .506. I am not sure if averaging the 02 tells me anything, but when checking it a in a few places at WOT it is in the low .8 range
Thanks, Mike
Thanks, Mike
RE: C6 LTFT Question using 7194 and the new update 8r07
Interesting.
You can use an average of the LTFTs from one bank to the other to base your adjustments.
The O2s will constantly vary at part throttle, but low .8XX seems a bit low at WOT.
What gear/rpm were you doing the logs at?
I don't remember what gear, probably 4th or 5th and about 2200 was one spot I just looked at. There is so much data on the C6 it seems.
When check further there are 0 in some spots that was bringing it down when I averaged the WOT 02 (I just averaged a bunch of spots when I saw 100% on the command throttle). It’s usually .86 to .87 taking out the 0 lines.
Also I am having a problem attaching my log to this post for anyone to look at.
you can email my your log if you want... lewis DOT eaton AT gmail DOT com
The E-mail I sent was returned.
E-mail me if you can so I can reply with the file.
log was too big LOL excel wouldn't open up the whole 16MB csv file LOL
anyway, what I did get out of it is... your average ltft's are at +1.9xxx and +2.2xx
so I would start by adjusting your injector slope to -2%.
you also looked a little lean at WOT, so adjust both rpm ranges in the PE setting to be +2%.
sorry it took a while to get back to ya... I had 6 other people that sent me their logs too LOL
What a busy guy....hey Lew, when are we gonna set you up with CMR so you can start doing tunes????
that's what I wanna know??!!! where's that CMR software???
I could be your Northeast Satellite Office...
I know, I know... one thing at a time... k, so I'll take the tranny support FIRST, and THEN the CMR software...
Whiterock1
Thanks for the reply. I tried to send you an excel file with 5 tabs, 10 minutes each to be under the 65,000 line max for each tab in excel 2003 but the E-mail was returned as file too big. In the 2007 version it opens all 229,000 lines of data. I d/l the demo version of office 2007.
I am going to change the tune and re log some data tomorrow hopefully.
Thanks again
Mike
Thanks again
Mike
yeah, workin' on your log now... takin' a while... that's a lot of friggin' data for the macro's to go through line by line... LOL
be back to ya in a bit...
EDIT:
ok, well, I don't see any WOT runs in your log, so I can't help ya with any PE settings. Did you accidentally filter out the WOT data??
For your normal cruise/driving, your average ltft's were 3.64 and 2.71 - so, adjust the injector slope to be -2%.
Do another log, with a good WOT run in there, and let's see where stuff is at. You only need to log for about 20 minutes - that'll be enough data. And then send me the unfiltered log.
Thanks!
-Lew
EDIT:
Thanks!
-Lew
