Hi,
I have Predator part number 2022, serial number 0001030, on my 2004.5 Dodge Ram 2500 Cummins 5.9 HO.
This is the second truck I've put it on, I originally bought back in 2005 and installed, removed and bought another truck and just installed. I have had a check engine light a few times and pull no codes but cleared with code reader. Recently, about 2 weeks after installing the truck will quit while driving and won't restart. First time it quit at slow speed backing out of the driveway and I pulled the codes, there were none, erased anyway and the truck started back up. Yesterday it quit at freeway speed and would not restart after nonexistent codes erased. I had to unplug the module and the truck started and ran. As well noticed in the middle of this that the fuel gauge is acting up. OTW no other symptoms. Any thoughts. Should I remove the battery negative and let something on the ECU reset?
Mark
2004.5 Dodge Cummins 2500
RE: 2004.5 Dodge Cummins 2500
Yes, try pulling both battery cables from both batteries to see if it resets and helps.
