2008 pontiac g8 gt- disable displacement on demand
2000partspro
Post by 2000partspro »
predator is u7194, version is v.9r23, vehicle is a 2008 pontiac gt with a 6.0litre v8.
RE: 2008 pontiac g8 gt- disable displacement on demand
what is the question?
DoD can be disabled if you'd like....
2000partspro
Re: RE: 2008 pontiac g8 gt- disable displacement on demand
mikel wrote:what is the question?
vehicle is a 2008 pontiac g8 gt with the 6.0l v8. my predator is a u7194 with version v.9r23 loaded to the g8. please provide the steps ( or how to print the procedure ) to go thru the process with the predator to be able to disable the cylinder deactivation. thank you for you time.
RE: Re: RE: 2008 pontiac g8 gt- disable displacement on dema
select the performance tune that you want to install... then select Modify Tune... then select the DOD (or AFM) menu... then select Disable... then press ESC button a few times and install the tune...
Return to “General Questions”
