I'm new to this forum stuff and don't know if this is the correct place to post so please don,t beat me up for these questions...
U7198
part # 329763
v.9r17
2001 chevy silverado 2500HD 4x4 crew cab 8.1L allison transmission 4:10rear end
My modest modifications are as follows:
285/75r 16in tires
airaid cold air intake (original tube)
airaid throttle body spacer
30% towing 30% off road 40% hwy/in-town driving
I have uploaded the 87 Octane tune but i want to get the best out of the predator that i can. If you can guide me in selecting the right parameters for my modifications and needs or guide me on how to acquire a custom tune, I would greatly appreciate it. I will attach original factory tune, Thank you
Cold air intake and thottle body spacer parameter question
- lopezoriginalbd12208322cga.grg
- original tune
- (290.44 KiB) Downloaded 103 times
RE: Cold air intake and thottle body spacer parameter questi
You will need to run the tune for about 300miles. Then do some datalogging and make sure to adjust your injector pulse width. Read up in the stickies! Then you will want to adjust your shift/transmission settings to your liking. Then do a constant load log and save it to your pc, then a WOT log and save to your pc. Then contact Diablew for a custom tune. Im getting an average of 16mpg around town and almost 20mpg while on the freeway with the 87tune and my adjustments. It does run stronger as well. Im in the middle of doing some logging so I two can get a custom 87tune done. Hope this helps some?
