using 89 on the 87 octane setting
Posted: Wed Aug 24, 2011 8:29 pm
by maxxguy1
new here and want to purchase one of your tuners
will running 89 octane hurt anthing when set to 87 tune, will also be using truck for towing which is its primary use.
U7137
truck is a 04 ram 1500 5.7
RE: using 89 on the 87 octane setting
Posted: Wed Aug 24, 2011 10:15 pm
by 69rrbruce
Minimum of 87 octane on tune.
Re: using 89 on the 87 octane setting
Posted: Wed Aug 24, 2011 11:28 pm
by brandy16
maxxguy1 wrote:new here and want to purchase one of your tuners
U7137
You will be fine. No problem running an 87 tune on 89 oct. You just can't do it the other way around.
RE: Re: using 89 on the 87 octane setting
Posted: Thu Aug 25, 2011 9:49 pm
by maxxguy1
ok thanks will the program hurt my truck wich has 200000 miles on it. reason asking somebody told me it would blow the engine
Re: RE: Re: using 89 on the 87 octane setting
Posted: Fri Aug 26, 2011 10:09 pm
by brandy16
maxxguy1 wrote:ok thanks will the program hurt my truck wich has 200000 miles on it. reason asking somebody told me it would blow the engine
Who ever told you that has a blown mind. You will be fine as long as you are not haveing any issues before you load the tune. You know a rod knocking ect.
Re: RE: using 89 on the 87 octane setting
Posted: Sat Aug 27, 2011 10:09 pm
by brandy16
69rrbruce wrote:Minimum of 87 octane on tune.
What is a 98 Hemi Dakota?
Posted: Tue Aug 30, 2011 7:27 pm
by bighemitex
brandy16 wrote:69rrbruce wrote:Minimum of 87 octane on tune.
i'm betting he might be one of the people who is lucky enough to have a dak with a hemi transplant. it would be sick to have a rcsb dak with a hemi.
Posted: Tue Aug 30, 2011 7:46 pm
by 69rrbruce
I did a Hemi swap in my 98 Dakota Sport.....check out my swap thread on Dakota-Durango forum:
http://www.dakota-durango.com/forum/sho ... ostcount=1
RE: Re: RE: using 89 on the 87 octane setting
by abuelo
There is not a 87 octane tune (at least named like that) I have read here & there (do a serch on the forum) that the MPG booster tune is actually a 87 octane tune if that is the case (I think that Mikel posed that somewere) you will be fine using 87 fuel with that tune.
Re: RE: Re: RE: using 89 on the 87 octane setting
Posted: Tue Aug 30, 2011 10:15 pm
by bighemitex
abuelo wrote:There is not a 87 octane tune (at least named like that) I have read here & there (do a serch on the forum) that the MPG booster tune is actually a 87 octane tune if that is the case (I think that Mikel posed that somewere) you will be fine using 87 fuel with that tune.
my predator has a 87 octane tune. Pretty sure that's on all the DSPs for the Ram.
RE: Re: RE: Re: RE: using 89 on the 87 octane setting
Posted: Tue Aug 30, 2011 11:02 pm
by abuelo
ok....then you should be fine ussing that fuel.
Posted: Tue Aug 30, 2011 11:03 pm
by brandy16
I have an 02 dakota 4x4. I was thinking of puting in a 5.7 but was told by some that the 5.7 was to wide to fit.
