2011 Mustang GT A/F
a_gorman
2011 Mustang GT A/F
Post by a_gorman »
Just wondering when the wideband reading for a/f will be available through the trinity?
RE: 2011 Mustang GT A/F
our guys are working on that as I type this ;)
a_gorman
Post by a_gorman »
I see Revan Racing is currently using this feature, what are we looking at for an update release?
email sent :)
budlun
Re: RE: 2011 Mustang GT A/F
Post by budlun »
mikel wrote:email sent :)
Is that good news? [email protected] :D I really hate to bother you,but anxiously waiting.be glad to test anything you have,or ignor my dumb ass if I'm a pain in yours.Thanks Bud
RE: Re: RE: 2011 Mustang GT A/F
Test crom is coming your way Bud!
It has the WB PIDs, but they are not added to the existing layouts yet, go in and add them to the layouts and you'll be good to go ;)
budlun
Post by budlun »
Thanks Mike
budlun
Post by budlun »
Success, Thanks again Mike, :D works great!
phzlher25
Post by phzlher25 »
What about this for the Shelby GT500?
2011 Ford Mustang Shelby GT500
Wrxified
2011 V6?
Post by Wrxified »
Will the test crom work on a 2011 V6? Do you mind if I give it a shot as well?
RE: 2011 V6?
should have a release version up today ;)
Darkside323
RE: 2011 V6?
Post by Darkside323 »
Hello just wonder if the A/F gauges will work on an 07 GT500
concoursd
RE: 2011 V6?
Post by concoursd »
2011+ Mustangs and 2009+ F150's only. The earlier mustangs do not have wideband oxygen sensors
Scuba-Matt
RE: 2011 V6?
Post by Scuba-Matt »
2012 Mustang GT
Got the update with the wide band, When I go to customize my own gauge layout I can only get one lambda gauge and one A/F . No previsions to change both to A/F or both to lambda. Are these reading off both O2 sensors or only one? Thanks, Matt
concoursd
RE: 2011 V6?
Post by concoursd »
Lambda and A/F are measurements of the same thing using both sensors so if you set both gauges to one or the other it would be like have two identical gauges at all times which is not useful in my opinion. Lambda is totally not useful because it based on the assumption that a lambda value of 1 = an A/F of 14.7. A/F ratio = lambda x 14.7
Usually the lambda shown with the predator or the trinity is the commanded (intended) value that the PCM wanted. If that is the gauge you have pulled up along side the new a/f ratio gauge then it may be useful to see if the lambda (commanded value) matches the actual a/f ratio picked up by the sensors.
Return to “Trinity Ford Gas”
