How to make a log with my C6?
GizmoZ
Post by GizmoZ »
Since I understand there is a problem with logging data with the U7194 and we are supposed to use a laptop, how would I go about logging some data that way? I have never logged any data before so I am trying this for the first time. Thanks for any help.
RE: How to make a log with my C6?
connect the Predator to your cars OBD port.. connect the serial cable from the Predator to your laptop. Start up the dataviewer app on your laptop to select the parameters to log and click the Record button at the top to start recording/saving a log.
GizmoZ
Post by GizmoZ »
Thanks Lew, sounds easy enough. You know what's coming next! Thanks for all your help.
:D this is turning into a full time job... ha ha ha ha....
no problem man...
GizmoZ
Post by GizmoZ »
If you won't have time to get to it I understand completely. You should be charging money for this service :D
no problem at all man... send it when ya got it...
lewis DOT eaton AT gmail DOT com
