Trinity/Zt-2
Posted: Mon Sep 05, 2011 5:18 pm
by HalsMag
I haven't found the settings to get this to read with the Zt-2 gauge.
Anyone have the trick?
I've set the purple wire to linear, and both it and the white wire show leaner reads than the LCG display or PC log.
RE: Trinity/Zt-2
Posted: Tue Sep 06, 2011 8:51 am
by gizmodo
What are you entering for the values? What version ZT-2 do you have? You should use 9.6 and 19.6 for the low and high values respectively.
You also need to ground the analog cable to the same place as your ZT-2 is grounded.
RE: Trinity/Zt-2
Posted: Tue Sep 06, 2011 2:01 pm
by HalsMag
Changed to those settings, but it's still about .3 low on that scale at idle.
RE: Trinity/Zt-2
Posted: Tue Sep 06, 2011 2:29 pm
by gizmodo
Your ground might be bad then. Be sure the analog cable gets the same ground as the ZT-2.
RE: Trinity/Zt-2
Posted: Thu Sep 08, 2011 2:55 pm
by HalsMag
Same ground.
RE: Trinity/Zt-2
Posted: Fri Sep 09, 2011 1:36 pm
by gizmodo
Check all your connections then. I have the same setup and the AFR in the Trinity is dead on with that of the ZT-2.
